I placed the part (Assemble>Insert) named Column into another file.
When I did several errors popped up.
Opening the original file I don't see any errors.
Any insight as to why I am seeing the error in the assembly?
Interesting behavior and thank you for reporting this! The really interesting thing is that the fillet3 seems to fail catastrophically when Column is inserted into Component Errors. . I note that if I right click on fillet3 in Column design and Convert to DM feature, the issue seems to subside. To me this indicates some conflict with the Timeline and the fillet command; however, I will log this with development and let the experts review this issue further.
Thank you again for reporting this!
Best Regards,
