I have modelled a bottle which has a very thin wall section of just under 1mm, now when I use that as a tool to cut through the mold base (i.e. Target Body) it leaves me with a thin cut out instead of the entire shape.
I've tried adding fluid fill to it so that it may appear as a complete solid part, but that doesn't seem to work.
How do I overcome this?
Solved by zakaria_kassar. Go to Solution.
Ok, so I just converted the bottle to a BRep Mesh and used that which did the job, however I lost all the detail in the neck area...
I don't think I undertsand the problem fully. Because the tool is shelled (bottle) there is inner part after the cut operation that perhaps unwanted. If so can you create a Brep surface with Patch->Offset command with 0 offset distance? This Brep surface can then be used to split the target (mold) body.
How did you convert the bottle tpo Brep surface?
If possible can you share the model? That would really help us to assist. Please share a public link (with password if you wish and email me password at anand dot karyekar at autodesk dot com)
Anand
Fusion360 Development
