During the turtorial there is a step that requires you to click and drag or slide the switch. I can not get this function to work.
Will you please help me?
Also in the next turtorial where you assemple the lamp I can not find the bodies section (which is accidentally is the first assignment)
Solved by joel.palioca. Go to Solution.
When you click hold and drag the switch does anything happen at all? You shouldn't need to preselect anything, but rather just click and hold on the body and you should be able to drag it along the slider. If you are still having problems, something to look at would be your slider joint that you created in the last step. The click and drag is trying to allow only movement that is supported by the joint you created, if the joint for some reason isn't working correctly this could also cause a problem.
For your question about the assemble tutorial, we are aware there is a problem with this tutorial. What you can do is skip to step 5 and everything should look correct. It looks like the file that was included with this tutorial was already a couple steps ahead. We are in the process of providing fixes for this area.
Cheers,
Apologies for the inconvience, to get things working correctly for this tutorial what you can do is disable contact sets prior to the move. See the image below on how to turn off contact sets.
We have plans to get this fix in one of the upcoming updates to resolve any further issues.
Cheers,
