After I duplicate items with the circular or rectangular tool, I can no longer trim them.
Solved by innovatenate. Go to Solution.
Could you make a Screencast of this issue? I tried to reproduce this issue, but I found that I can still use the Sculpt > Modify > Trim tool after patterning surface bodies. I found the same to be true for the split command in the Model Workspace.
The sketch trim command didn't even cross my mind! Thanks for reporting this. I can reproduce this behavior as well. I'll have to do a bit more research. I will circle back and let you know what I find out.
Doug,
Thanks again for posting this question. I overlooked this originally. There is a caveat when trimming patterned sketch entities. When you create a sketch pattern, there is a small glyph that will enable you to re-edit that sketch pattern at a later time. At this time, this will prevent you from being able to trim patterned sketch entities. You can choose to delete the glyph, which will remove the ability to later edit the sketch pattern, and then trim the sketch entities. I've made a short screencast below to demonstrate this.
Please review the screencast and let me know if you have any questions.
