Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
cartesian coordinates
2 REPLIES 2
doug.ford
412 Views, 2 Replies
Is there a way to go to a particular coordinate without drawing two lines to get there?
Tags (1)
2 REPLIES 2
innovatenate
in reply to: doug.ford
Below is ScreenCast where I use the project to sketch command, and dimensions to position a sketch entity without having to draw lines.
 I hope that helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
doug.ford
in reply to: innovatenate
Thanks!!
As you can tell by the question, I am a beginner.
Doug
