Hi, since Autodesk just updated (Sept) I cannot seem to find/open any of my projects. I have clicked the data grid in the top left hand corner of the 360 design window (that now opens when I click on the icon in my launch tray at the bottom of the page) but clicking on any of the folders there doens't do anything. I have then clicked on the browser triangle and got the browser page up where I can see the projects I am a member of and tried to open one of them, but I keep getting a dialogue that says:
"Your browser is trying to launch Autodesk Fusion 360. If the application is not installed on this machine, please download and install Fusion 360."
Which I have already loaded and just updated and nothing else happens. Please could you help me as I have to get a project finished and not being able to ppen my files is really hampering me.
I am running a Mac on OS X V 10.8.4
Solved by charegb. Go to Solution.
Solved by Sjayabal230. Go to Solution.
When you get to your Data Panel, make sure you double click on the folders. Does this open it or are you seeing issues? If you are available for a quick call, please let me know a number I can reach you at and I'd be happy to call you. My direct email is sanjay.jayabal@autodesk.com
best regards,
Sanjay Jayabal.
Hi Chris,
You are probably in the Samples project. Inside your Data Panel, do you see a Project drop down (top left in the Data Panel) - it probably says Samples? If you drop that down are you able to see your projects?
best regards,
Sanjay Jayabal.
This is the dropdown that allows you to switch projects to see all your data.
Bankim
Willyam what is this? Willyam are you
@kaptinscarlet wrote:Hi, since Autodesk just updated (Sept) I cannot seem to find/open any of my projects. I have clicked the data grid in the top left hand corner of the 360 design window (that now opens when I click on the icon in my launch tray at the bottom of the page) but clicking on any of the folders there doens't do anything. I have then clicked on the browser triangle and got the browser page up where I can see the projects I am a member of and tried to open one of them, but I keep getting a dialogue that says:
