I can't seem to pattern or mirror components, only bodies, faces, or features. Is there a method or feature I'm missing?
Luke
Solved by TrippyLighting. Go to Solution.
Thanks TrippyLighting!
Nice video, the result of mirror whether you get single body or multiple bodies depends on whether there is a chance to boolean them. If the bodies intersect we give booleaned (combined) result for pattern bodies. It's not dependent on which component is active. Hope that clarifies.
I noticed that mirror components work in Direct Modeling mode. I will check with the development team here.
Anand
Fusion360 Development
