I'm not sure if this has been discussed or not, but I'm noticing some weird acitivity since the latest update happened. Whenever I try to split the body of ANY object, even in a new document, the splitting tool is always moved down further once the action is complete.
For example, I'm splitting a cyllinder right in the center with a circle sketched as the took. The preview shows the tool slicing through the top and bottom of the ciyllinder perfectly centered. When I click "Ok" and perform the action though, the circle is off center and incorrect. I'm unable to figure out why the heck it keeps doing this on any object and file.
I was using this command just a couple of days ago before the update, and I havent had a single issue until now.
Hey AoBfrost,
Thank you for reaching out. Can you post a screenshot of what you are seeing? I just tried to replicate what you just described with Phil and we couldn't get the behavior you are describing. Nevertheless, I'll be glad to help you out.
