The June update has introduced a serious problem for me, I cannot escape orbit once initiated. It's the exact same problem that 123D had a few releases ago. I open a scene, orbit the view and it gets stuck in orbit with no way to stop it. The machine is a bog standard win 7 pc. The May and earlier releases worked fine so I don't know what has changed but I cannot use F3D. All I can do is quit the program once it happens.
Any ideas?
Solved by jasperF8RUK. Go to Solution.
Hi - I'm sorry to hear you are having trouble with orbit. I have not seen this myself. Are you having issue using the orbit command from the navigation toolbar (pic below)? <ESC> key is not working?
If you prefer and as a possible workaround you might use <SHIFT> and the middle mouse button to orbit (I actually prefer this rather than explicitly entering/exiting orbit command each time from the navigation toolbar).
I'll ask the team if anyone has seen this.
Thanks for reporting this and apologies for your inconvineance.
-Nathan
Hi Nathan,
thanks for the quick reply. Orbit works properly with Shift>MMB and the Nav bar, the problem is that I have a habit of hitting the view cube unconciously and it's ok as long as I move the mouse from the cube in towards the viewport area. If I move to the outside of the screen (to the right) it will seemingly go out of bounds and lock orbit mode. I'm a lefty and so moving the cube left to right to orbit is my normal mode... hence the problem. That same as that action will also cause the cube/view to spin wildly. It appears that the mouse gets confined by the screen space, forcing the orbit to operate in an increasingly confined area until it becomes like a orbital singularity, it the mouse were permitted to do a screen wraparound (like in various numeric dialog boxes) it would likely fix the problem. I don't know if this is doable. In the meantime I've disabled the viewcube.
Try to reproduce this by rotating from the cube to the main screen border. If you wiggle it around the right of the screen edge it should reproduce the problem unless it's just specific to my configuration.
Could you provide your machine information?
Mac or Windows? Detail OS information will help us address it.
Thanks for bing this up!
This is still an issue, fixes have been promised in 2015, and in 2017, it is now 2021 and this bug still exists.
-Mac OS X Catolina 10.15.7 (19H2)
This happens to me a couple of times every day. The help article says to restart Fusion 360. So that's what I do. But it' frustrating. See attached for a video. Escape key does not exit orbit mode.
@smeggy can we please mark this as "no solution"? It says it was solved but it has not been.
See attached for a video with repro steps on Mac OS Catalina 10.15.7 (19H1217) with bluetooth mouse.
Simply click and hold the orbit cube then drag over the tree/browser and then release.
I have the same issue. Once I select orbit, I can't deselect it.
In general orbiting, panning and zooming are clunky in Fusion360 compared to other 3D apps I have used where moving around using gestures on a MacBook Pro are natural and fluid.
In general gestures do not always work as if the app forgets that the setting "Use gesture-based view navigation" is enabled.
same problem here. REALLY FRUSTRATING!!!
FIRST TRACKPAD GESTURES STOPPED WORKING SOME MONTHS AGO
NO ONE SEEMS TO CARE
NOW THIS?!?!
REALLY?!!?
THIS IS CRUCIAL, BASIC, ELEMENTARY STUFF.
FUSION IS BECOMING MORE AND MORE A NIGHTMARE TO USE
COULD THE DEV.TEAM PLEASE START TO SOLVE THESE CORE ISSUES
BEFORE ADDING MORE USELESS FEATURES?
THANKS A LOT
I also have this issue. MacOS. If I click on the top right cube to rotate my project, all ok unless I hold my mouse button down for more than 10sec. After that the rotate function locks ON. To unlock I have to restart Fusion. Odd is the other tabs are not locked.
Hi, I have a student using Fusion 360 on a chromebook in a university setting. He is complaining of this and esc does not release him from Orbit view. Please tell me his solution IS NOT to restart the program.
Surj.
I have the same issue on my Mac and have been trying for days to schedule support! Autodesk support is terrible so far, I'm starting to regret paying for the subscription. As a hobbiest it was a lot of money and it doesn't really get me any support. Sad...
I hope you solve this. I have had zero help or follow up from Autodesk. The sales guys keep calling but I think I have to look at "is the software fit for the job?" and I have to say "mostly, but not with a faulty steering wheel".
Thanks, I don't have a lot of hope, it looks like this bug has been around for 8+ years. It got worse after I paid for the software. How is that even possible? Very disappointed in Autodesk.
I am able to reproduce this issue as well. It is super annoying.
Mac OS 10.15.7
