Why can't I delete the sketch points you see in this picture? I can select them. I'm sure they're selected because I can long hold and choose "sketch point". They won't delete. When I move, rotate, and translate them it seems like weird things happen.
Solved by NicolasXu. Go to Solution.
Hi codefoster,
The picture were not attached somehow. Could you check it?
In some situation, a sketch point is not allowed to be deleted, such as, the center point of a circle, an end point of a sketch line, etc. It would be greatly helpful if you can attached the model so we can take a deeper look to figure out if it’s a software problem.
Best Regards,
I simply forgot to attach the image, but you solved it anyway. I have some archs in my sketch and I'm sure now that the sketch points are the centers. That makes sense. Perhaps there should be some way of notifying a person when they attempt to delete one that can't be. Perhaps a simple popup in the lower right corner like other notifications.
Actually, after selecting such points and accessing Delete command from the toolbar or marking menu, we can see the selection is clean in the Delete dialog, which means the Delete command don’t think such points are valid input.
Maybe we should disable the Delete command if the selection only contains such entities. I will pass your feedback to the development.
Thanks and please keep the feedback coming!
How do I remove these pink points?? Picture is attached.
Thank you!
Hi Shreyansb,
Welcome to the community! The points and curves shown in pink are projected objects. They are used to build the association with other objects out of the current sketch.
When we create sketch objects, we might want to refer to existing vertices, edges, etc. and keep the association. For example, we could create a sketch line starting from the midpoint of a body edge. When the bod edge moves, we might want to have the sketch line updated to the new position.
Since the pink objects are generated based on other existing objects, they cannot be moved by dragging. We can use “Break Link” to break the association or just delete them. However, the capability of associative update will be lost.
As for the pink points shown in your screenshot, they are the end points of the projected line or the center of the arc, so they can only be deleted together with its parent object.
Here is a screencast to show how the associative update works and what will happen if deleting the projected curves.
Best Regards,
Thanks for the response, which was quick !
FInally, will these pink and yellow points appear in the final rendered image?
Thank you
Hi Shreyansb,
We're happy to assist you for any Fusion related questions.
Sketch objects will be hidden automatically when enabling Ray-Tracing rendering in Render workspace.
We can also toggle the sketch visibility from the browser anytime, even in Model workspace.
Best Regards,
Greetings,
I don't think I understand why these "stray sketch points" appear and what I need to do to avoid them altogether. I imported traced "letters" spelling "REFLECT" and have shared the file. Please see http://a360.co/2gTRcKQ
Should be downloadable. Please see sketch to see what I'm talking about.
I exported the paths from Adobe Illustrator as a DWG and imported it into Fusion 360. I seem to always have these "stray points" within each sketch and they cause some serious problems during my sketch process. What can I do to avoid them - what am I doing wrong? I read the above and I don't know if this is the same kind of issue.
Thank you in advance to whomever!
In relation to feedback to the development team, I find those little sketch 'dities' and points left behind REALLY REALLY REALLY (insert a swear word) annoying!!!!!! Especially when you can't delete them.
Matt
Hello
I'm having a problem where I had a projected line, but deleted it and now I have floating projection points into two sketches.
I believe the second one is causing a loft to profile to fail for some reason? I am trying to select the entire sketch/chain as a profile, but in the loft feature box it will only allow me to select a 2 of 4 segment?!? I have a nearly identical profile in a different sketch that works fine. Maybe this has nothing to do with the pink dot...but help on either count would be much appreciated.
