Can't create new design or upload CAD data or Open Designs
4 REPLIES 4
jeffchuber
937 Views, 4 Replies
The new update seems to have broken a lot of things.
I'm running Windows 8.1. I'm running version 2.0.1193 of Fusion 360.
I can't:
  • Open designs - click and does nothing at all
  • Upload CAD data - opens an empty modal window
  • or Create Designs - opens an empty modal window
What can I try to fix this? I can't get any work done.
4 REPLIES 4
innovatenate
in reply to: jeffchuber
Can you test signing out and signing back into Fusion 360?
Let me know if this helps or if the issue is ongoing.
Nathan Chandler
Principal Specialist
jeffchuber
in reply to: innovatenate
Hey Nathan,
That did not help. The same behavior is happening.
What next?
Jeff
innovatenate
I sent you an e-mail, directly.
Nathan Chandler
innovatenate
I just wanted to add a note that performing a clean uninstall and re-install resolved the issue.
Jeff - let me know if you run into this again!
Nathan Chandler
