Hey there, did some quick searching but I cant find what seems to be the problem here.
I am trying to loft between two profiles that I sketched. I click both profiles, the loft shape appears to be correct, but the OK button is grey'd out and not clickable.
There is no error shown and I wish there was so I could figure out what is wrong...
Thanks for helping!
Solved by taylorsizemore. Go to Solution.
It would be helpful to have the data file. Can you export the file as .f3d file type and attach?
Hi Taylor,
I thought I would take a look at this as well, but was unable to replicate the issue that you are having. I tried selecting profiles in opposite orders and it seemed to work either way. The only thing that comes to mind after quickly looking at it is that perhaps something else got selected accidently, though the image looks right to me. I have attached the lofted part in case you need it to move forward, but hopefully someone will have a good solution for you as to what happened.
James
I don't know what happened either, thanks for looking at it.
After some more selecting, unselecting and reselecting it worked... I created a simpler set of shapes and did a loft to be sure I could, and after that my complex shape worked. Weird.
Thanks again,
Taylor
