if I select all blue pipes and thicken them at once two pipes seem to be one object not.
If I select the one pipe alone and add the thickness it is all fine.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Solved by Phil.E. Go to Solution.
Claas,
This is as designed. The reason is the Thicken command itself. This command does not "consume" the input surfaces. So when you thicken to create a new body, you are making a new body on the active component, and leaving the old one where it was.
The alternate you want is to do the thicken operations one at a time. In each case you are allowed to pick join, new body, etc.
Claas Kuhnen
