I really have a hard time getting reliable results when projecting stuff from faces/other sketches to a sketch.
I've prepared a short screencast to show an actual case:
https://screencast.autodesk.com/main/details/8ee06718-94d3-4a6b-ba11-1608b7663a3f
(i tried the embed code but the forum said it is invalid HTML?)
Any idea/help?
I unfortunately can't share the design but i think that's not special to my design.
EDIT: after finishing the screencast i noted that even if i click line by line to project and accidentally click a few pixels to the left or right of a line and hit the face the complete projection get's "destroyed" in a way that the faces don't work anymore.
I'm wonderng if the profiles are being hidden from view when a single sketch has a large number of profiles. This may be on purpose for performance reasons. Have you tried right clicking on the Sketch in the Browser and seeing if the Show Profiles/Hide Profiles option is available? You may need to select Finish Sketch after the projection.
Could you share an F3D model with me? Feel free to e-mail it direct to Nathan (DOT) Chandler (AT) Autodesk (DOT) com.
On a side note if you like to embed a ScreenCast, you have to select the Embed Link from the ScreenCast webpage. There's usually some <iframe =...> text in it. It also lets you size for the Autodesk Discuasion group as a bonus. Then take the embed link and copy and paste it directly into the HTML tab in your forum post.
are you on os x? you can use quicktime for a screencast and many online storage systems such as Google drive to host the file. Or for Windows there are other pretty neat tools such as
http://www.techsmith.com/jing.html free 5 min limite
or
http://www.screencast-o-matic.com/ free 15 min limite
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
OMG - I did not see the code there hahaha silly me.
BTW while the embedding did not work going to the screencast on OS X finally allows me to see it full screen. which seems not to work with OS X and embedded screencasts.
Claas Kuhnen
I suspect that Frank is correct, this is a bug. Nathan, if you have the model, we can take a look. This should work OK.
Jeff Strater (Fusion development)
Just wondering what ever became of this? I'm runing into the same issue I think.
C|
Do you have a file you could share with us?
How to share a public link in Fusion 360:
https://screencast.autodesk.com/Main/Details/2b205403-2b70-4121-be9c-5ef9aa6b9134
If you would prefer to keep the file private, feel free to e-mail it to me at nathan.chandler@autodesk.com.
It's the same file I posted a bit ago in another thread.
http://forums.autodesk.com/autodesk/attachments/autodesk/124/4232/1/CantEditSketch1.f3d
Sketch1 was created by doing a project body silhouette. I was monkeying with the file a bit so it would be better to create a new sketch and do a new projection. I've tried a few times and it doesn't create a closed profile.
C|
