I am in process of making a tutorial to explain the differnece between bodies and components and use a bicycle frame as the basis for it. I came across this strange behavior when trying to extrude the ring sketch for the bottom bracket. Here's a little screencast.
Solved by brucehuang. Go to Solution.
Very sorry to know you are facing this issue. It's definitely a bug.
I knew there was a similar bug which was fixed for a while. Not sure if it's a regression. I'm the developer of this area. It would be very helpful if you are willing to share me the model (email: bruce.huang@autodesk.com). I'll look into it and give you feedback soon. Thanks in advance!
Bruce (Fusion Development)
Hi Bruce,
I've invited you to the project. the file name is "Bicycle". I have worke aroud the problem, but you shouldbe able ot see the faulty extrusion for the bottom bracket in the in the timeline. I noticed that when I selected the ring Fusion stated I had one bject selected, but when the extrusion was completed (incorrectly) and going back into it and editing it is said I had 2 objects selected.
Hi Peter,
Thanks very much for inviting me into the project. I will look into it tomorrow and try to fix it ASAP. Hope it can go into next release update.
Hi Peter,
I found a reproducible workflow for the issue. But I'm not sure if it's the right one you met, so want to confirm with you. Is the model you shared to me exported from somewhere? If it's true, I think I get the right scenario for fixing the bug (the fix will be available on next release).
Bruce (Fusion development)
Hi Bruce,
All the geometry in the file was created in Fusion 360 Ultimate 2.0.1407
Hi Peter,
My question above may be confusing. I mean if the problematic model is exported by the "Export..." or "Save Copy As" functionalities. Currently, I only can reproduce the same issue by exporting a model, then adding sketches in the existing sketches of exported model. If it's true, I think my fix can avoid this type of cases in new release. Please let me know if your scenario is not the case. Many thanks for your help, Peter.
Hi Bruce,
No this file was not exported or saved as. It was a new file adn then geometry was created in fusion and just saved and given a file name.
There is another thread wher a very similar or even the same bug is posted by another user and I am not sure you are aware of this, so here is a link to that thread.
