AWOL Settings Control
5 REPLIES 5
jdavis417
486 Views, 5 Replies
While I haven't been in Fusion 360 much, isn't there supposed to be a Settings button here?  I'm using Chrome browser on a Windows 8.0 machine.
TIA,
JD
5 REPLIES 5
Phil.E
in reply to: jdavis417
You are correct. I've seen this before but it was fixed just by rebooting. After rebooting the machine is it still missing?
Phil Eichmiller
Software Engineer
Quality Assurance
jdavis417
Phil,
     While it took two re-boots, the control has reappeared.  Thanks.
Phil.E
Thanks for letting us know, and sorry for the trouble.
Can you recall what might have happened to cause this? A crash or other strange event?
Thanks!
Phil Eichmiller
Software Engineer
Quality Assurance
jdavis417
Phil,
     No, there was no apparent cause.  The control failed to appear after a complete shut-down and re-start (the next day), then again after one re-boot.  It took two re-boots before the control button reappeared.
     The inconsistent problems are the worst, aren't they?
Respectfully,
JD
schneik-adsk
Please let us know if you see this again. We will try and replicate the problem here too. Any tips that might help are appreciated.
Kevin Schneider
