hello
i want to know whats the use of "auto look at the sketch"?.what will happen if i uncheck it?
thank you
Solved by jeff_strater. Go to Solution.
Auto Look At Sketch will change your view so that you are looking straight at the sketch. For instance, if you sketch on this face of the cube:
Fusion will rotate the view so that you are looking at that face of the cube, and so that the sketch X axis is horizontal, and the Y axis is vertical:
When you exit the sketch, Fusion will restore your previous view.
It's fine to un-check this option. I have it unchecked, because I find the view change to be annoying. The only effect will be that this view transition will not occur. You can always decide later to look at the sketch manually, by selecting the sketch in the browser, right-clicking, and choosing "Look At"
Jeff Strater (Fusion development)
this option is handy but its flips my view sometimes, its very annoying, how can i left it On but without screen flips?
