Is it possible to change a solid body's material in the Fusion 360 Beta? When I try to using the 'Material' command (from the marking menu) I see lists of materials pop up, but all with a 'lock' symbol presented when my cursor hovers over.
Solved by patrick.miller. Go to Solution.
Right-click the desired material and select "Assign to Selection". The lock is referring to whether you can edit the material.
