Active Member
mixnmatch
Are material selections enabled in the beta?
202 Views, 2 Replies
04-02-2013 09:00 AM
Is it possible to change a solid body's material in the Fusion 360 Beta? When I try to using the 'Material' command (from the marking menu) I see lists of materials pop up, but all with a 'lock' symbol presented when my cursor hovers over.
Please use plain text.
Employee
patrick.miller
Re: Are material selections enabled in the beta?
04-02-2013 10:45 AM in reply to: mixnmatch
Right-click the desired material and select "Assign to Selection". The lock is referring to whether you can edit the material.
Patrick Miller
Senior Content Developer
Active Member
mixnmatch
04-02-2013 06:24 PM in reply to: patrick.miller
Thank you, that did the trick.
