I find that if I marquee select (with select through checked, and going left to right) and touch another object with the selection rectangle, that object becomes selected when I subsequently choose the Move tool. This seems like a bug.
https://screencast.autodesk.com/Embed/Timeline/b2db89d4-71cf-4a70-9d68-2baafb43eb0b
Solved by Phil.E. Go to Solution.
Certainly looks like a bug Ron. I will do some testing and also check with the Fusion development team.
Jon
Ron-
You have discovered an as-designed feature. The selection window you draw in the video completely surrounds an edge on the small box body. This selected edge is promoted to a Body selection for the move command. This way you can just click an edge of a body, right click, and pick Move, thus eliminating the need to do window selections moving single bodies.
-Phil
Thanks, Phil. I think at some point I knew that.
