Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Solved by NicolasXu. Go to Solution.
Hi Claas,
Can you show us where the problem was? I checked the Sketch 20, it seems to be fully constrained by dimension.
Best Regards,
Claas Kuhnen
Hi Claas,
If I interpret the purpose correctly, it seems you want to make the horizontal line symmetric against the vertical line. Actually, the Midpoint constraint would try to connect the midpoints of both selected lines. However, in this case, the dimension 13.31mm, horizontal constraint and midpoint constraint will result in an over-constrained state.
Besides the approach you have used in the model, you may probably want to try the Symmetry constraint. I recorded a screencast to show the steps. Hope it helps.
Best Regards,
Claas Kuhnen
