Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Z direction
3 REPLIES 3
prabu27
465 Views, 3 Replies
Z direction
hello,
                     when giving process setting core differ from cavity it automatically takes towards Z dirction is cavity side ..
i want to change towards Z dirction as a core how to change the direction. is it possible to change ?
3 REPLIES 3
kristen.kilroy
in reply to: prabu27
You are able to rotate your model in Moldflow to whichever direction you would like. Since you are attempting to reverse the cavity and core sides, this may be the easiest option. In the ribbon, go to: Home > Geometry > Utilities > Move > Rotate.
Hope this helps!
Kristen Kilroy
_______________________________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
prabu27
in reply to: kristen.kilroy
Hi Kristen,
                      actually my doubt is i dont want want to rotate the whole model, i just want to Change Towards Z dirction is Core and opposite direction is cavity like that , actually why i am asking this i found somewher that setting is there but i forgot where i found,  i tried but now i can't find.. so please help me findout the option where it is?
thank you for ur reply...
Right click on mesh and select properties
edit the Mold properties as you required
you can choose options : Top-Core; Bottom-Cavity
