Dear all,
I have doubt in the winkle gate design. Is the winkle gate should always in straight or it can be in a certain angle?
As my part has constraint over giving the winkle gate straight, i have hade with 25 deg. Is this design is practically feasible?
Please share your views.
Wikle gate - Angled
Winkle gate - Straight
Regards
JK
Solved by sadashiv. Go to Solution.
It depends on the gate insert and the parts surrounding you are gate
check the link below
Do check the topic with the mold designer. I think it might be possible to make this type of gate if you can place you are nozzel
http://www.eppm.com/x/guideArchiveArticle.html?id=29976
Hello Sadashiv,
Thanks for your information.
I checked with the mold designer and he accepted to incorporate in the mold as it is practically possible.
Regards
JK
