Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
what is Inventor Server x86 Autodesk Simulation Moldflow Synergy?
5 REPLIES 5
729 Views, 5 Replies
Good morning everyone.
To free some space on my hard disk i found this directory about 3.5 GB.
Are these files useful? or can i delete without anly problem?
How can i see where my temporary files go?
thanks
5 REPLIES 5
Hi
Regarding temporary file storage,: Please have a look at  the solution posted by nordhb in below post :
      http://forums.autodesk.com/t5/simulation-moldflow-insight/modifying-temporary-directory-for-mfi-2014...
mppkumar
Hi
Those are temporary files generated when working with Autodesk Inventer; these files can be deleted if not required.
Moldflow Analysis temporary files are stored in this location : C:\ASMI 2015 Temporary Files (By default) however we can change the location.
refer the below image to check the temporary file location and to change the location. (Press Ctrl+J to open Job manager window)
M P Pradeep Kumar
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
in reply to: mppkumar
Thanks for the answer of temporary files.
About the "inventor files", i never used inventor on that pc. Only Moldflow...
Hi everyone, i have a simple question, please:
Why do i have in the temporary files some files older than 2 days, if i set 2 days in the jobs manager options?
Will i have any problem if i go to the temporary files directory and manually delete everything inside? (to free space)
thanks
mppkumar
Hi
You can manually delete the temporary files and free space from your hard disk
Before deleting ensure you have all the analysis results on the respective study file
Logically, it should auto delete those temporary files which are older than 2days... need to cross check it
M P Pradeep Kumar
