Hi all,
I ran Fill+Pack+Warp analysis for a part, once completed i could able to find deflection values depicted in analysis log. But warp results plot were not available in results task bar.
I did try by restarting the computer, but it didnt work .
Whats is the reason and solution for it ?
P.S: Attached image is reference for the same.
Thanks in advance
Hi Dinesh,
I m no sure what may cuase this issue. Have you looked at your anlaysis log to see if the warp analysis was completed
Successfully? You will probably have to re-run the anlaysis.
Hi Dinesh
Try copying Temporary Files to the project folder
and right click on "Results" ---- select "Add Default Plots"
Let me know if this solves your problem
Pradeep Kumar
Please check your disk space in your project folder and temp folder.
it may be lack of disk space.
Hello Dinesh,
It may cause due to lack of disk space, Make enough space in disk & Try rerun the analysis without deleting the temp files.
Hope this will help you to view warp results.
Hi Aniq
Thanks for reply, in analysis log it shows warp succesfully completed.
I did try by re-running the analysis, but it didnt work. But i got results when i renamed the study and ran it again.
Hi Inba & Sabari,
Thanks for reply !
I did check my computer it has enough memory and addtional information is i fired two analysis. For one i got warp results, but for the other one i stuck up with that issue.
Hi Dinesh,
Yes, for whatever reasons, sometimes warp analysis doesn't converged / complete / Flow to Warp interface file is not generated or lack of disk space or server / project folder may not be accessible from computer.
In these cases, you may 'Create Copy' of this study file, rename it or may change process parameters of warp settings & re-run the analysis.
I am sure analysis will provide you results. This has observed in rare occasions.
Mayur
Hi Mayur,
Thanks for reply. Yep i agree to you, but is there anything we can do to prevent this happening in future ?
