Hi all,
Just ran a CFPW on a DD model in 2015. After simulation finished, no warp results in the task pane????.
Log file says warp analysis completed sucessfully. Had to "add new plots" to get warp results even though they are set up in the default results.
Any ideas??
Adam
Any one of following can help you to retrieve the results
1. Check space in C:drive or temporary directory.. there must be enough memory to generate results.
2. If you are running at server, there must be network error.
3. Try to close the study and reopen the study. Then check for results
4. Try to close the project and reopen the project .Then check for results
5. Import the study with results in new project of study. Then check for results.
6. if not re-run the analysis for only warp.... hope it will generate results.
7. if not re-run the complete analysis till warp.... hope it will generate results. Try this as a last option
At-least one of the above the will surely solve your problem...
