Discussion Groups
Simulation Moldflow Insight
Active Member
timotheusruf
warp animation does not show any animation, nor any warped geometry
517 Views, 11 Replies
04-16-2013 12:12 AM
hi
i am using synergy 2014 with XP64bit.
when displaying a warp result with a deflection of f.e. 5, the result is shown correctly.
when i am starting to play the animation, the deflected model jumps back to a "unwarped" model with a scale factor of zero. the animation is running as indicated by the changing scale factor. but the model stays undeflected and doesnt move at all. when stopping the animation it stays undeflected.
it jumps back to scaled deflection when i am switching the warp result off and on again
i asked support but they cant reproduce this bug. (they dont have windows xp though)
has anyone the same problem?
any thougths?
regards
timotheus
Please use plain text.
Employee
Alex.Bakharev
Re: warp animation does not show any animation, nor any warped geometry
04-16-2013 01:45 AM in reply to: timotheusruf
I have checked my install of Insight 2014 and warpage animation works the way I would expect so.
Do you mean that the result shows the warped shape overlayed with  the "undeformed model"? You can switch it of by a chackbox on the result's property:
Active Member
timotheusruf
04-16-2013 01:56 AM in reply to: Alex.Bakharev
no.
plz read my first post.
i have attached a picture of the warped geometry, and a gif of the animation.
Employee
Alex.Bakharev
04-16-2013 04:43 PM in reply to: timotheusruf
I cannot reproduce it on my version of 2014 Insight.
What version of Insight do you use? Sorry, for been not much of a help, I am mostly a solver guy.
Active Member
timotheusruf
04-16-2013 10:59 PM in reply to: Alex.Bakharev
hi
thanks for trying though! :smileyhappy:
as i said, i told support already and they can not reproduce either. (they use windows 7)
but fact ist, that i have the problem. i installed new drivers for the graphic card but nothing changed.
@alex  do you have windows xp as well?
my installation:
MikeHoyt1335
06-25-2013 08:27 AM in reply to: timotheusruf
Did you ever find a solution to this problem?  We are experiencing the same issue.
Employee
yannick.moret
06-26-2013 06:16 AM in reply to: timotheusruf
Hello Thimoteus,
we did tested on XP64 and couldn't reproduce your issue.
working on finding what could cause this issue, and to reproduce it.
Support didn't give up.
Regards
Yannick
MikeHoyt1335
06-26-2013 09:59 AM in reply to: timotheusruf
Ok .... I reset the animation display from the default of "accumulate" to  "current frame only" ... and it started working .
This is with 2014 SP1 ,,,, NVIDIA graphics card.
Active Member
timotheusruf
07-01-2013 12:46 AM in reply to: MikeHoyt1335
Hi Mr. Hoyt
when i change to current frame only, the animation is working. but of course as the setting "current frame only" indicates it does not show the whole range of the frames.
i have attached a exampel.
is it the same on your system, mr hoyt?
regards
timotheus
MikeHoyt1335
07-16-2013 10:49 AM in reply to: timotheusruf
Wanted to follow up on this issue  ... had mouse issues with monitors being "flipped" , IE one was in negative space in relation to prime monitor 0,0,0.
Had mouse issues with this, fixed it and the "warp" graphics now all work fine as well.
