Dear all,
In my part warp analysis is stop at 80% with out any error . i do not know why it is happening.
Detail are:
Mesh :- 60576 Element
Operating System: Windows Vista
Processor type: GenuineIntel Intel64 Family 6 Model 30 Stepping 5 ~2793 MHz
Number of Processors: 4
Total Physical Memory: 8125 MBytes (DDR3)
Regards
Vinod Tiwari
Hyderabad
Hello Vinod,
What is the type of mesh (midplane, D/D or 3D) you are using for this analysis?
If you are using midplane, try changing the Warpage analysis type (Automatic to small, etc)
Did you checked the drive space where the temporary files are getting created?
Try clearing the earlier temporary files created.
Regards
PK
Hello Vinod,
To echo PK, disk space may be a concern for your temporary directory. Also, as a warp analysis closes on finishing, the job manager may not update as frequently while it transfers data back to your project directory. Many times there is a delay in which the analysis may appear to not be running while it transfers this data.
Hello Rk & Justin,
Thank for your prompt reply of my question.
I had tried all possible way to solve this problem, even I format my m/c but the problem is same. (Mesh -fusion )
last week I had completed analysis three time bigger part without any problem (Mesh -fusion)
Regards
Vinod Tiwari
