when i am running a cool analysis i am getting the following error
**WARNING 702460** Beam element 33324 hasno circuit attribute assigned to it .check that a coolant inlet has been assigned to this circuit.
then how can i resolve this problem? i would appreciate receiving datails regarding it above.
about this question,i have created original file which is mpi format.pl download and unzip befor running in the Autodesk moldflow insight 2010 version. have a note have can 't delete on the "dumb layer" of the file. any idea to solve it, i can send it to them(because it is too large,can't attachment
skype name:kenny0755 can be discussion on line
Thanks for your reply,actually i have already checked all this,but the ploplem was somewhere else.may i have your Email?i send the moldflow file to you
Regards!
