I ran a simulation with a valve gate size of 4.0mm, then tried running the simulation again except changing the valve gate diameter to 3.4mm. I get the following warning and error message: Warning 304500 & Warning 304510.
Not sure what I need to do to correct the error.
Thanks.
These error messages you are receiving can be found in the local Help within Moldflow or by using the online help with the links below:
Error 304500:
http://help.autodesk.com/view/MFIA/2014/ENU/?guid=GUID-AD303427-22B8-426C-87DC-56D6C00F04FF
Error 304510:
http://help.autodesk.com/view/MFIA/2014/ENU/?guid=GUID-EDD5C77A-0F0C-4FAB-8E45-9EB64A4A431C
Hope this helps!
Thank you,
Hello Mike,
Based on my understanding, monotonic has to do with order relative to a sequence. For valve gates, this means that in modifying the diamters it changed the flow enough to alter the valve settings (such as pressure release or flow front).
Does your analysis fail immediately or runs for a little bit then fails? Can you provide screen captures of your valve gating profiles as well?
Thank you,
