For isotropic 3D solid materials, linear shrinkage is approximately one third of the volumetric shrinkage, where volumetric shrinkage is evenly distributed in all directions.
For transversely isotropic materials in thick parts, volumetric shrinkage is approximately equal to the shrinkage in the flow direction plus two times the shrinkage in the transverse direction.
For shell-like geometries, it is expected that the shrinkage in the thickness direction should be higher than the shrinkage in the plane of the part.
Shrinkage in the thickness direction is likely to be greater than one third of the volumetric shrinkage, while in-plane shrinkage should be less than one third of the volumetric shrinkage.
Many mold features act as constraints to in-plane shrinkage. If you are using a fiber-filled material, the orientation of the fibers in the plane of the part will limit shrinkage in this direction.
Shrinkage in the thickness direction is relatively unconstrained.
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
