Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Visible sink mark depth
6 REPLIES 6
1430 Views, 6 Replies
Hello~
I am curious what size would be the visible sink mark during the sink mark estimate. Anybody has idea if 0.025mm would be visible on actual part?
Thank you!
6 REPLIES 6
nishit78
I think it will depend on the light conditions and the angle at which you are looking at that area of the part. Also any surface texturing will help in hiding those marks. Personally, i think, under a certain configuration of these factors you will see it but numerically speaking it is not a high value.
Autodesk has a product called "showcase" that helps visualize what effects these factors can have.
You can also use the scaling option in the deflection tab of plot properties for that plot (sink-marks shaded) to exaggerate the visual effect
amwafwcel1
It depends on the what material you use , for the big shrinkage of the material, 0.01mm also can affect the appearance of the product.
madhukeshwart
Sink estimate to be less than 0.03 for most of parts is quite ok.  it can be  up to 0.05 for granied/painted.
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
tbloink
in reply to: madhukeshwart
What is granied? Would 0.05 mm apply to textured parts?
madhukeshwart
in reply to: tbloink
With textured or grained
Madhukeshwar Talwar
09600060862
nitinhadpe
Yes, I do agree with Madhukeshwar.
Midplane:
0.003 mm for non textured / mirror polished surface
upto 0.05 mm for textured (may be any kind)
