when materila is flowing through narrow side , there is rise in temeprature is observed
(may be due to shear heating )
and when materila is flowing through wider side , there is drop in temeprature is observed
i.e If these temperature difference is more than 5 deg C, then both the flow fronts may not fuse preperly &
may result in weaker weldline (in strength )
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
