Trying to import any file with more than one component. If I use an assembly file from Inventor, I always get the error message "No entities imported from CAD file". I get the same error when I try to import .stp, .iges, etc.
I think it has something to do with Design Link but I'm not sure. I've read in forums and in a training manual, that I should have a checkbox "Direct import using autodesk simulation...." and " process using autodesk simulation....". These boxes do not even appear.
Any help is appreciated!
Solved by kristen.kilroy. Go to Solution.
Inventor should work perfect and at least step should work even without all the other import filters available in MF.
Could you provide some screenshots?
I mean this is usually really something that your dealer / support should be able to answer you on a telephone call within minutes.
Nevertheless:
Can you import a STL file in Moldflow?
Have you tried via IV Fusion, or via *.SAT file format?
If that doesn't work, then there would be clearly something wrong with your installation or licence management.
Which version and servicepack of MF are you complaining about?
Best regards
Harald
you cannot import the assembly in the moldflow.
instedad of that, you have to export the each model with same co-ordinates.
and import the model for overmolding simulation or insert molding simulation using " ADD" option in the moldflow study.
It is possible to import most assemblies into Moldflow. The resolution for this is to update the service pack through the Application Manager or the link listed below.
-Kristen
Hi
Try with exporting the assembly file as *.stl and import in moldflow.... in this way it may work
Regarding Design Link:
"" I think it has something to do with Design Link but I'm not sure. I've read in forums and in a training manual, that I should have a checkbox "Direct import using autodesk simulation...." and " process using autodesk simulation....". These boxes do not even appear. ""
Check whether you have installed Design link during software installation; if not install it.
To check for Design link installation: Go to Options --- External Applications tab and check.
M P Pradeep Kumar
