Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Tooling graphics not inline with dimensions
6 REPLIES 6
mark.e.bessac
667 Views, 6 Replies
Wondering if anyone knows "why" when you set a beam size it shows much larger when the results are plotted. I know my customers will ask why the gates appear to be so large in the results.
Please see the attached pictures.
Thanks.
6 REPLIES 6
toofewfish
in reply to: mark.e.bessac
This has been reported as a bug thru support, but yet to see a fix.. Very annoying to explain to your customers time after time.
tim.vanast
but the results are correct for the size you specified, not the large size that is seen in the output plots.
PascalGosset
in reply to: tim.vanast
To Tim : it's false !
The results correspond to the gate section seen by Moldflow (a square) not the one you drawned (rectangular).
If you want to simulate a fan gate, modelize it using dual domain mesh and not beams.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
tim.vanast
in reply to: PascalGosset
Interesting, I was told by MF support that it calculates correctly.  I'll have to run a case study to see.
Tim
toofewfish
It's only a display issue. I've ran many, many analysis over the last year and half with this visual issue. The assigned properties are used for calulations, not the visual size... otherwise the results would be completely screwed up...
PascalGosset
in reply to: toofewfish
Sorry, I'm maybee wrong.
I tried to find an example and it doesn't work as I thought.
