Discussion Groups
Simulation Moldflow Insight
0 Kudos
Tooling graphics not inline with dimensions
390 Views, 6 Replies
04-09-2012 11:01 AM
Wondering if anyone knows "why" when you set a beam size it shows much larger when the results are plotted. I know my customers will ask why the gates appear to be so large in the results.
Please see the attached pictures.
Thanks.
Active Contributor
3 Kudos
Re: Tooling graphics not inline with dimensions
04-09-2012 11:06 AM in reply to: lznv0f
This has been reported as a bug thru support, but yet to see a fix.. Very annoying to explain to your customers time after time.
Valued Contributor
37 Kudos
04-10-2012 05:47 AM in reply to: lznv0f
but the results are correct for the size you specified, not the large size that is seen in the output plots.
Valued Contributor
18 Kudos
04-10-2012 06:00 AM in reply to: tim.vanast
To Tim : it's false !
The results correspond to the gate section seen by Moldflow (a square) not the one you drawned (rectangular).
If you want to simulate a fan gate, modelize it using dual domain mesh and not beams.
"Maybe Moldflow does not work properly, but the real world neither."
Valued Contributor
37 Kudos
04-10-2012 06:15 AM in reply to: PascalGosset
Interesting, I was told by MF support that it calculates correctly.  I'll have to run a case study to see.
Tim
Active Contributor
3 Kudos
04-10-2012 07:24 AM in reply to: lznv0f
It's only a display issue. I've ran many, many analysis over the last year and half with this visual issue. The assigned properties are used for calulations, not the visual size... otherwise the results would be completely screwed up...
Valued Contributor
18 Kudos
04-10-2012 07:54 AM in reply to: toofewfish
Sorry, I'm maybee wrong.
I tried to find an example and it doesn't work as I thought.
