Moldflow Insight Forum
Welcome to Autodeskā€™s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
To make Ring or Diaphragm gate in Mold flow
2 REPLIES 2
sharbaf
989 Views, 2 Replies
How can i make  a Ring or Diaphragm gate in Mold flow.it is mentioned that , it is possible to make runner but the problem is to make the gate (circular gate) and connect to runner.thanks
2 REPLIES 2
tim.vanast
in reply to: sharbaf
Yep, you'll need to create your gate with tri elements, not beams.  You can do it manually, or actually create geometry to represent the gates.  You can connect the beam elements all the way around the ring gate, or you can also create the runner with the gate in tri elements.  It can be done, but it takes more work than just using beams.
Tim
madhukeshwart
in reply to: tim.vanast
It will be recommendable to use 3D option, more accurate. Even create cold runner with 3d tetra elements.
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
