Hello Guys!
i have some doubts about "how make a tehrmoplastic overmolding analysis *fill + pack*.
i need release the analysis for a lens (First Shot PMMA Clear V052i and 2nd shot PMMA Red MI-7) the second shot has a 3 direct gate for each window Note all windows should be filled at the same time.
my question is the next, is necessary make the analysis for each window?? or is possible into the second shoot simulate the 3 windows at the same time?
i understood that overmolding simulations works only for two shots or material
image is attached.
Yes, you certainly should be able to simulate the second shot to all the three windows in one analysis. This is also the only way to make meaningful warpage results. The flow analysis should also be more accurate if you do the second shot in one go (at least for 3D analysis).
thanks Alex, but this analysis is in the first step, to find a potential processing window, and the gate definition is with yellow cones.
with this gate type, will be not a problem for the simulation? thats why because, it would have 3 separated parts for the 2nd shot without runner!
regards!
No. It is not necessary to make analysis for each window
Yes. Second shot will simulate 3 windows as a single part model
It is recommended to use feed sytem or model the feed system for both shots, not just with injection cones
currently this part is in mold design stage and i dont have the info available, for the future analysis i need consider the feed system.
thanks for your support.
yes you can do all 3 windows in 2nd shot,
Step:
selet 1st shot part and feed assign 1 shot
selet 2nd shot part & feed assign 2 shot
assign respective material form moldflow data base
for try you can model the feed as attached...
Regards
Aravind Halasur
