I started an Fill+ Pack + Sink + Warp analysis 16th of this month, which didn't complete till yesterday (25/06/2014). i am using 14GBRAM, NVIDIA Quadro 4000 Graphic, Hard disk with free space of 26GB. In past too we had issues of this sort, where analysis would run for a day or more. So we are planning to upgrade our system. My queries are related to that are:
Note: We are buying a floating Moldlfow Insight license, so if you can answer above question with Insight datas it will be helpful.
Solved by nordhb. Go to Solution.
information can be found:
Berndt
how many elements is your model and which mesh technology did you use ?
If analysis is really slow, you should look at windows task manager.
If you take more than the RAM you have available, it will use hard disk as memory to run and then analysis will be really slow. You can see that CPU activity will be very low because it has to wait for data to be transfered from disk, which is much slower than transfering data from memory.
Also, ensure you always run on the last service pack an dhotfix from your current moldflow installation.
We have following configuration
processor : Intel (R) Xeon (R) CPU W550 @ 3.07GHz 3.06 GHz
system : windows 7 - 64 bit system
RAM : 32 GB
And also ensure 150 GB FREE Space in system drive, where analysis will be running and temparory files are being copied.
We can run the study 3D STUDY with 35,00,000.
If you would like to run the analysis very fast, Go for HPC configurations.
Hi Dinesh and all the others,
my main issue is that I do not have a GPU compatible graphics board with enough mem (6GB needed) installed.
AND I found out a Windows issue with the page file handling - if I let Windows manage the size of the page file automatically, then at round about 30GB I receive a Windows pop-up telling "out of memory".
If I set a page file size on my own 120GB, then it fills up until 107GB.
Anybody the same?
Jay
