We are finally getting ready to upgrade to 2015 at my company. We have about 25 engineers that use communicator 2014 to view results.
Are they going to be able to view communicator files that were published with 2015?
Solved by mppkumar. Go to Solution.
I thought:
If those Users install Communicator 2015 they could also view the 2015 result files (and the older ones, too!)
I found this:
Autodesk Simulation Moldflow Communicator compatibility
Please use Autodesk Simulation Moldflow Communicator 2015 to view Moldflow Results files (*.mfr) exported from Autodesk Simulation Moldflow Insight 2015 .
So it was clear.
But then:
The only Communicator to dl is Version 2014.
So I double that question of yours, even if I did not stumble across the issue so far.
Regards
Harald
Yes ... You can view the results exported from ASMI 2015 in 2014 Communicator
Pradeep Kumar
