Hi Friends
Am a Beginner in AMI
Am learning Thro' tutorials . Previously i have done this Fill Analysis
Tutorial but now it shows an error as soon as i double click my Start Analysis
option. Refer the attached image. Same model_4_analysis.sdy file runs well in
another system.
Actually the error msg asks me to look on for possible error in analysis log
But log shows
"C
as above .... Kindly refer the image .
Kindly help me out in this. Thanks in advance .
this information in screen output means that the AMI2012 solvers has not been installed on the host you try to run analysis on.
Seems as only Synergy 2012 is installed.
Please, install the AMI2012 solvers on the host in question, and make sure solver licenses are available for host as well.
When set up, relaunch analysis.
See http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17773602&linkID=13030537 for installation information.
Hope this helps.
Berndt
