Good Day,
I would get technical support about Moldflow. We will produce a part by PMMA material. You can find the basic dimensions of part which I mentioned on the attach. When I make sink mark analysis on moldflow, I see sink marks about 0.0056mm-0.0028mm on analysis.
According to my experiance; At these values, we haven't seen any sink mark on the surface of real parts which are produced with different material.
A) Is there any special values for PMMA material for non noticeability on real parts?
B) What do you think about our values(0.0056mm-0.0028mm)which we see on sink mark analysis?
Process conditions;
Filling pressure = 70 Mpa - 9 seconds.
Fill time = 1.2 seconds.
Mold temp. = 80C
Melt temp. = 240C
The part dimensions : Lenght 340 mm and nominal thickness 2mm
Gate type : Valve gate(Hot runner system)
Gate diameter : 2.5mm
Flow path ratio(For material) : 170mm(The injection location is middle of part)
Thank you!
In this case i suppose your part's Nominal thickness is less than or equal to 3mm approximately then there is a quite 100% chance of getting sink mark free part.
Mayur
Try with very fine mesh and during meshing use advance front. hope it helps
