Hi all,
I'm doing a moldflow analysis using 3D mesh. I'm trying to obtain sink mark index and sinkmark depth results but i'm not getting them. Can anyone please tell me, which type of mesh to be used and which type of analysis sequence to be used to get sink mark index and sink mark depth?
Thanks in advance. 🙂
thank you for your response, I set my model to dualdomain mesh and got sink mark index as you suggested. I tried to generate midplane mesh for my model but i couldn't. So i guess i should accept sink mark index only. can you please tel me what percentage value of sink mark index means?
All,
Is it not possible to just use the "sink marks estimate" result, or is this simply not reliable? I'm using this frequently on DD and 3D models and I thought this was essentially the same as the "sink marks, depth" result. After reading the documentation, I may be more confused than when I started.
Jeff
