Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Sink Mark Depth Result in Dual Domain
5 REPLIES 5
511 Views, 5 Replies
Is there any way one can get sink mark depth result using dual domain meshing?
5 REPLIES 5
nordhb
the Sink marks, depth result plot is generated when using Midplane mesh type and analysis technology.
The result is not available for Dual Domain mesh type and analysis technology.
See: Sink marks, depth result
Hope this clarifies.
Berndt
Berndt Nordh
madhukeshwart
in reply to: nordhb
You can refer 'the Sink marks estimate result' displays the calculated depths of sink marks in the part, when using DD or 3D mesh
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
inba.oneway777
Sink mark results are more accurate in Midplane & 3D mesh. DD mesh unable to predict the sink mark accurately. because DD mesh works based on the mesh matching.
Inba Sudhahar D
Mail: inba.oneway777@gmail.com
Phone: +91-9884929216
if the answer is accepted as a solution. Give Kudos as appropriate to further enhance these forums. Thank you! .....
teopado89
in reply to: inba.oneway777
Hi everyone,
i'd like to ask: what about "sink marks index" in dual domain analysis? Can i consider this result reliable?
inba.oneway777
in reply to: teopado89
Sink mark index in %.
for ex: sink mark index is 0.2% at the location of 1mm thick region.
the depth of the sink mark is 0.002mm.
Inba Sudhahar D
