Discussion Groups
Simulation Moldflow Insight
Member
heinemma
Simulation of In-mold label - What is meant by "interface conductance"?
162 Views, 1 Replies
01-15-2013 10:50 PM
High there!
I try to simulate an in-mold labeling process with AMI 2013 and now search for a proper value for the interface conductance of polycarbonate film with a thickness of 250 µm. The value rquired from Moldflow should has the unit [W/m^2*°C].
Either the film manufacturers (Bayer & MacDermid) nor the professors at my university know the term interface conductance. They all reference to the heat conductivity of polycarbonate that is about 0.2 W/m*K but has an different unit!
My questions are:
What is exaclty meant by the "interface conductance". Is this the heat transfer coefficient U?
Can I divide the heat conductivity by the film thickness (0.2 W/m*K : 0.00025m) to get the "interface conductance" of 800 W/m^2*K ? Or can somebody please give me the proper value for the "interface conductance" of polycarbonat film.
Thanks for supporting me!
Please use plain text.
Product Support
nordhb
Re: Simulation of In-mold label - What is meant by "interface conductance&q
01-16-2013 10:58 PM in reply to: heinemma
the thermal conductivity for the polymer in the in-mold label, you will get when assigning the polymer material.
Interface conductance specifies the ability of heat to be dissipated from the selected region of the mold.
A greater interface conductance means the greater the ability for heat to be extracted.
See Help:
Modeling > Cooling system > Cooling considerations > Interface conductance
or
http://wikihelp.autodesk.com/Simulation_Moldflow/enu/2013/Help/2.0Insight/0670-Modeling670/1431-Cool...
Berndt
Berndt Nordh
