Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Simulation of fillers with flake shape
1 REPLY 1
321 Views, 1 Reply
Hello we try to simulate some test bodys (Plates 50x50x1,2and3 mm). Our goal is to predict the orientation of zylindrical copper plates.
Now the Question is how to define the filler properties, there you need to specifie a l/d ratio. Our plates are 1µm thick and have an Diameter of 38µm. Is the ratio in this case 38 or is it 1/38?
Has anyone tried to simulated plate shaped fillers yet and can make some suggestions on how ci-value and rsc-value have to been set to reach good results?
Would be great to hear from you.
Thanks in advance
Martin
1 REPLY 1
nordhb
regarding aspect ratio for flake and mica fillers:
Aspect Ratio  Reinforcement Type
0< AR < 1        Oblate or disk-like shapes (eg, mica, flakes)
AR > 1             Prolate or cylindrical shape (eg, fiber)
AR = 1             Spherical or cubic shaped fillers
For flakes as in your case it should be 1/38, 0.0263
Berndt
Berndt Nordh
