Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Shrinkage Properties
3 REPLIES 3
karelkalip
926 Views, 3 Replies
I was researching warpage results in 3D analysis but i could not find any information about shrinkage values.
Then i checked material details=>Shrinkage properties . No value has been written.
Does it means warpage analysis have been made without shrinkage ?
Best Regards
Levent
3 REPLIES 3
Alex.Bakharev
in reply to: karelkalip
Shrinkage propeties are used to make some corrections in 2.5D (midplane and fusion) analysis. 3D analysis predicts shrinkage from the first principles.
karelkalip
in reply to: Alex.Bakharev
Thanks, but how can i find information about 'First principles' ?
mayur_dhumal
Hello Lavent,
The following shrinkage models are available in this product:
1) Uncorrected residual stress
This option will be selected when there is no shrinkage data available for the material. In this case, the Fill+Pack analysis predicts the residual stress values within in the part, based on the flow and thermal history during the molding cycle.
2) Corrected residual in-mold stress (CRIMS)
This option is the default when shrinkage testing has been performed on the material. This shrinkage is the most accurate because it is obtained by correlating actual tested shrinkage Values with Fill+Pack analysis predictions.
3) Residual strain
This option is selected for those materials where the CRIMS model was found to not adequately describe the shrinkage behavior of the material.
For more info refer:
http://wikihelp.autodesk.com/search?source=help&product=Simulation Moldflow&q=shrinkage models&language=ENU
Whenever shrinkage values are not given that means it is using first shrinkage model.
Best Regards,
Mayur.
