Hi all, I've found that there're two different ways for setting the second shot in a 3D overmolding analysis.
The first one is setting the elements as Part (3D) and than editing the properties of elements turning the shot field in "2 shot". The seond way is just setting the elements as Second Overmolding Component (3D).
In the first way some process parameter of the second shot could be edited, but not in the second one.
Moreover results are similar but not the same. Temperatures patterns are quite different. Can you explain which are the diferences between settings and their influence on results?
Many Thanks.
