Discussion Groups
Simulation Moldflow Insight
Member
siskomas
Select facing issue
116 Views, 1 Replies
04-14-2014 01:21 AM
Hello to all,
I'm using sinergy 2014 and when I want to select only the facing triangle mesh with the proper command turned on, this often doesn't work (it didn't work also with the previous versions). Is there a way to fix it?
Thank you.
Francesco
Please use plain text.
Valued Contributor
tim.vanast
Re: Select facing issue
04-15-2014 07:02 AM in reply to: siskomas
I have found similar issues that the face only select will select some of the elements on the other side.  The work around that I have found is that it is sometimes improved to rotate the part a bit.  Then it sometimes selects only the facing element.
Good luck,
Tim
