Discussion Groups
Simulation Moldflow Insight
Valued Contributor
0 Kudos
Save Quick Access Toolbar
174 Views, 2 Replies
08-01-2012 08:49 AM
Hi, I've putted some tools in the Quick Access Toolbar.
When I close Moldflow and I start it again the tools there are no more.
It seems not to be saved.
If I open the file SynergyState_enu.xlm in the
....\AppData\Roaming\Autodesk\Autodesk Moldflow Insight 2012\Release
I see:
  <QuickAccessToolBars>
    <QuickAccessToolBar ContentFile="/AirSynResourcesI18n;component/Resources/Xml/SynergyRibbon.xml">
      <Content DefaultCommands="31">
        <Items Count="14" AreCustomizeVisibilityItemPositionsFixed="True">
          <Item Cookie="Item=ID_New_New Project_" IsVisible="True" />
          <Item Cookie="Item=ID_Open_Open Project_" IsVisible="True" />
          <Item Cookie="Item=ID_ImportGeometry_Import_" IsVisible="True" />
          <Item Cookie="Item=ID_Save_Save Study_" IsVisible="True" />
          <Item Cookie="Item=ID_Undo_Undo_" IsVisible="True" />
          <Item Cookie="Item=ID_Redo_Redo_" IsVisible="True" />
          <Item Cookie="Item=ID_ActionHistory_Action History_" IsVisible="True" />
          <Item Cookie="Item=ID_Print_Print_" IsVisible="True" />
          <Item Cookie="Item=QAT_Sep1_Separator_" IsVisible="True" />
          <Item Cookie="Item=ID_QATCapture_Capture_" IsVisible="True" />
          <Item Cookie="Item=ID_CaptureOptions_Capture Options_" IsVisible="True" />
          <Separator Style="Line" Width="7" />
          <Item Cookie="Tab=ID_Reports_Reports_Reports/Panel=ID_ImagesPanel_Image Capture_Images/Item=ID_SaveImageToFile_To File_" IsVisible="True" />
          <Item Cookie="Tab=ID_Reports_Reports_Reports/Panel=ID_ImagesPanel_Image Capture_Images/Item=ID_SaveAnimationToFile_Animation_" IsVisible="True" />
        </Items>
        <StandardItems Count="11">
          <StandardItem Cookie="Item=ID_New_New Project_" />
          <StandardItem Cookie="Item=ID_Open_Open Project_" />
          <StandardItem Cookie="Item=ID_ImportGeometry_Import_" />
          <StandardItem Cookie="Item=ID_Save_Save Study_" />
          <StandardItem Cookie="Item=ID_Undo_Undo_" />
          <StandardItem Cookie="Item=ID_Redo_Redo_" />
          <StandardItem Cookie="Item=ID_ActionHistory_Action History_" />
          <StandardItem Cookie="Item=ID_Print_Print_" />
          <StandardItem Cookie="Item=QAT_Sep1_Separator_" />
          <StandardItem Cookie="Item=ID_QATCapture_Capture_" />
          <StandardItem Cookie="Item=ID_CaptureOptions_Capture Options_" />
        </StandardItems>
but in "StandardItem Cookie" I see nothing compare "Items Count".
How can I do?
thanks
Employee
7 Kudos
Re: Save Quick Access Toolbar
08-03-2012 12:58 AM in reply to: biricio
Did you try with 2013 ?
There was an issue with 2012 and windows 7 for quick access toolbar which has been solved for 2013.
Valued Contributor
0 Kudos
08-03-2012 02:49 AM in reply to: yannick.moret
Hi, thanks for the answer.
Unfortunately I have the 2012 and my company for now does not want to go to 2013.
Do you think changing the code (SynergyState_enu.xlm) you can do something?
thanks
